I just purchased a 2000 Infiniti G20. It has a SR20DE with 94,000 miles. The woman I bought it from kept every receipt, and I can trace her oil changes to every 2500-3500 miles. From 2004 till now, she had the oil changed at the local corner lube shop. Prior to that, the Infiniti dealer took care of it.
I would like to keep up on the maintenance, and hope to get recommendations on the oil and filter. I plan on using it to take my daughter back and forth to school (40 miles r/t occasional stop and go). Also, I noticed she had the transmission fluid flushed once at 40,000. Is that something I should take care of right away? If so, recommendations on fluid and filter would be greatly appreciated, as well as coolant suggestions, and any other preventative maintenance that I should follow up on.
Thanks in advance! I cant wait to get started!
