I have a highly tuned turbocharged 4 cylinder engine which runs a 3 stage dry sump pump. My 3 gallon sump tank is in the trunk of a sedan and the to/from lines are insulated to hold heat. The car even when run on the track never go's above 175 on oil temp (taken from block sensor).
My problem is that when hot (and I dont cosider the temps I have to be hot enough for the cars good) I only get 14-17 lbs of pressure when idling. It is also street driven 50-100 miles per week. The pressure is fine running 20w/50 when running and perfect on top end of rpm scale. I cannot adjust the pump location and it will be difficult to do a gear for it (1 reason is because I dont know the math and the avail belts are size limited in my application. What I need to know is whether I can move up the idle pressure with the viscosity of oil I need yet still get my required pressure at 7800rpm? I have an option to heat the tank before starting so initial startup would be with fully heated oil. I dont understand this stuff well enough to risk an engine I have this much money/time/blood in, so if you are knowledgeable please give me your experience.
Thanks,
Rod
Thanks,
Rod
