- Drivers side, Upper ball joint
2 - Drivers side, Outer tie-rod end
3 - Drivers side, Lower ball joint
4 - Drivers side, Inner tie-rod end
5 - Drivers side, Pitman arm (at relay rod)
6 - Passengers side, Idler arm (at relay rod)
7 - Passengers side, Upper end of idler arm mount
8 - Passengers side, Inner tie-rod end
9 - Passengers side, Lower ball joint
10 - Passengers side, Outer tie-rod end
11 - Passengers side, Upper ball joint
One of the Chevy truck message boards shows the pics with the various zerks shown and noted with arrows. If I find it will post the link here.
I copied the pics and printed them out..... went into my binder where I store info etc regarding maintenance on the truck.
I believe the 4x4 and 4x2 have the same number and location.
I replaced the one hard-to-get-at zerk with one having a 90-degree angle. Easier to get at.
