This should probably go in the oil add. forum, but I need lots of eyes on this because I (may) need quick help -
I just added about 3/4 pint of Seafoam (a bit more than the recommended 1/2 pint) to my 5qts of 8k mile M1 oil (I decided not to add new Rotella just for this short Seafoam run - will do so for the Neutra run). But I was thinking the run would be a run - then I looked at Seafoam's web site and saw where it stated to add Seafoam to oil "1 HOUR BEFORE OIL CHANGE". Is this true? I was planning to run it out to 300 miles or so.
Plse advise!
Thanks!
Plse advise!
Thanks!
