Amsoil ACD 10W-30 Kubota 105X 567 hrs
Indiana
Make: Kubota
Model: 105X
Engine: 105 hp turbocharged 4 cylinder
Oil used: Amsoil ACD 10W-30
Hours on sample: 567
Hours on Tractor: 637
Sump Capacity: 11 qts.
Oil Filters: EaBP100 & EaO26
Oil analyzed by: OAI
For reference here is the link to the previous two reports on the same oil: The First Two Reports
Iron 30
Chromium 0
Lead 2
Copper 40
Tin 0
Aluminum 10
Nickel 0
Silver 0
Silicon 14
Boron 1
Sodium 0
Magnesium 16
Calcium 3670
Barium 0
Phosphorus 1080
Zinc 1349
Molybdenum 0
Titanium 0
Vanadum 0
Potassium 0
Fuel VIS @ 100 C 10.65
Water 0
Soot/Solids 0.3
Coolant NO
TBN: 7.44
OXID: 26.0
NITR: 13.0
F-SOOT: 0.39
I was having trouble logging in, so my brother was kind enough to allow me to log in under his name.
Any comments on the report? Overall, I am pleased with the results. However, I will also confess I don't know enough about oil testing at this point to pick out any problems. Does anybody have any thoughts on the copper level?
Thanks,
Bobby Johnson
Does the beast have an oil cooler? The oil could just be picking up Cu as it ages.
I would say maybe it's time to change the oil now or maybe 200 more hours or so. Over 500 hours - you got your money's worth out of the oil. Pretty darn good IMHO. The viscosity does not change. TBN is killer. Cool.
Did you mention what kind of air filter?
