Hi,
I have a 2005 Chevy Silverado basic work truck with a manual transmission. Although my maintenance schedule dictates a fluid change at 100K, I had a local garage perform that service at 50K by swapping out 3.5q of GM Syncromesh Fluid (as recommended by the owner's manual.) At $20 per quart plus labor, this wasn't cheap.
Now (approximately 6 months and 27K miles later) the transmission drain plug is weeping slightly, and the fluid is collecting onto the exhaust pipe so that a slight odor can be noticed. I currently have over 67K miles on the truck, most of it primarily highway commuting (with a few trips to the fishing hole thrown in!)
I asked a local technician at a transmission shop (not the garage that initially performed the transmission service) to check the problem and try to rectify it, and he informed me that it is very hard to keep this weeping/leaking from occurring just due to the thin nature of the synthetic Syncromesh fluid. He removed the plug, put his thumb over the hole to stop all the fluid from draining, put on some JB Weld, and replaced the plug with approximately 1/2 quart of new fluid, until it reached the appropriate fill level (1/4" below the fill plug). He also recommended that I disregard the owner's manual and have the transmission serviced at approx. every 30K miles, which I can certainly do, although I would want to try and stretch that interval out if possible.
Can anyone out there comment on this? Does his observation that there will be slight leakage no matter what I do seem correct? Does shrinking the maintenance interval to 30K sound reasonable, or would it be overkill? I am really concerned because the amount of transmission fluid in the pan is only approximately 3.5q and I am planning on keeping this truck long enough for my 4 year-old niece to use it for driving lessons in the future (her mother will be buying her a BMW, no doubt, so that girl will need some good country driving sense that will be helped by a slow-moving, full-sized truck with a 5-speed and a long clutch throw.) Plus, I really like the truck!
I am, as always, grateful for any helpful advice I get in this Forum. Thanks in advance!
