Looking thru the lists of topics, I don't see one that covers the above, but here goes anyway. I also am a user of an old tractor forum (Yesterdays tractors) and the oil issue comes up often. As you probably know all old tractors have flat tappets, so there is concern with the removal of zinc from most motor oils. Some have gone to diesel oils like Rotella or Delo. Also, in the old owners manuels, they suggest 30 wt in the summer and 20 wt below 32 degrees. (non detergent) I don't think reliable detergent oils were available in the 50's or earlier. What do you guys think about motor oil for these old beasts?
