30
35
1
30
4
2
1
22
3
3397
11
1130
1341
12
51
5
3
1
17
1
1
25
16
4
2993
23
1118
1292
4
2
3
1
1130
22
2
3397
11
06/13/07
13,598
SAMPLE DATE
ALUMINUM
ELEMENTS IN PARTS PER MILLION
UNIVERSAL
AVERAGES
UNIT /
LOCATION
AVERAGES
57-64 >410 415 INSOLUBLES
WATER
ANTIFREEZE
FUEL
FLASHPOINT
IN ºF
SUS
VISCOSITY
@ 210 ºF
cST
VISCOSITY
@ 100 ºC
VISCOSITY
INDEX
SUS
VISCOSITY
@ 100 ºF
cST
VISCOSITY
@ 40 ºC
TEST
VALUES
SHOULD BE
TESTED
VALUES WERE PROPERTIES
CHROMIUM
IRON
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
MANGANESE
SILVER
TITANIUM
POTASSIUM
BORON
SILICON
SODIUM
CALCIUM
MAGNESIUM
PHOSPHORUS
ZINC
BARIUM
MI/HR ON OIL
62.1
416 EAST PETTIT AVE
FORT WAYNE, IN 46806 (260) 744-2380
©COPYRIGHT BLACKSTONE LABORATORIES 2006 LIABILITY LIMITED TO COST OF SAMPLE ANALYSIS
P.O. NUMBER CC: Visa (Prepaid)
WALLY: The universal averages column shows typical wear from this type of engine after 5600 miles
on the oil. Your oil was in service for 4592 miles and all of the wear metals, except aluminum,
matched up well with those averages. The high aluminum comes from pistons and it is unusual to see
this much from a diesel. No contaminants were found and the oil's viscosity was normal, so they can
be ruled out as a factor. We suggest trying a shorter oil change interval of around ~3000 miles and
check back for another look at aluminum before trying to extend oil use.
KJCRD
D08972
EQUIPMENT MAKE: VM Motori
EQUIPMENT MODEL: 2.8L Turbo CRD
FUEL TYPE: Diesel
CODE:
UNIT NUMBER
CONTACT:
NAME:
ADDRESS:
LAB NUMBER:
PHONE:
FAX:
OIL USE INTERVAL: 4,592 Miles
OIL TYPE & GRADE: Amsoil Series 3000 5W/30
MAKE-UP OIL ADDED: 0 qts
OIL REPORT
E-MAIL:
ADDITIONAL INFO:
COMMENTS UNIT CLIENT
4,592
MI/HR ON UNIT
2
WALLY
44/27114/284 REPORT DATE: 6/25/07
35
1
30
4
2
1
22
3
3397
11
1130
1341
12
51
5
3
1
17
1
1
25
16
4
2993
23
1118
1292
4
2
3
1
1130
22
2
3397
11
06/13/07
13,598
SAMPLE DATE
ALUMINUM
UNIVERSAL
AVERAGES
UNIT /
LOCATION
AVERAGES
WATER
ANTIFREEZE
FUEL
FLASHPOINT
IN ºF
SUS
VISCOSITY
@ 210 ºF
cST
VISCOSITY
@ 100 ºC
VISCOSITY
INDEX
SUS
VISCOSITY
@ 100 ºF
cST
VISCOSITY
@ 40 ºC
TEST
VALUES
SHOULD BE
TESTED
CHROMIUM
IRON
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
MANGANESE
SILVER
TITANIUM
POTASSIUM
BORON
SILICON
SODIUM
CALCIUM
MAGNESIUM
PHOSPHORUS
ZINC
BARIUM
MI/HR ON OIL
62.1
416 EAST PETTIT AVE
KJCRD
D08972
FUEL TYPE: Diesel
CODE:
UNIT NUMBER
CONTACT:
NAME:
ADDRESS:
LAB NUMBER:
PHONE:
FAX:
OIL REPORT
E-MAIL:
ADDITIONAL INFO:
4,592
MI/HR ON UNIT
2
WALLY
