What am I doing wrong? I have vertical filters on both of my cars. When changing the filter, I poke a hole in the bottom to drain the oil so that when I loosen the filter, oil won't run down my arm. Only, it isn't working. I poke a hole and let it drain. When it stops dripping, I loosen the filter and oil spills out, running down my arm. What can I do to prevent that and where is that oil coming from.
