Ever had one of those problems you just can't seem to fix? Man, I am getting frustrated by this one.
2001 Jeep Cherokee 4.0 had a leak in the A/C system. Dye was used and the leak quickly located. Mechanic changed the accumulator and the hoses that lead into and out of it.
But since getting it back, all the coolant has leaked out of the system. Twice. Mechanic cannot find the new leak, even after using the dye again. Said he tried last week to pinpoint it spraying water to areas he couldn't see and looking for the dye-stained water. Still didn't work.
And here's the tricky part. The Jeep blows cold air, cold air, cold air, and then all of a sudden the coolant is gone. A week after he recharged it this last time, it was blowing 46-degree air a week later. Four days after that, it's not blowing any cold air at all and there's still no dye to be found.
Any help would sure be appreciated.
-Scott
-Scott
