If I recall correctly, Slick50 uses a detergent. I think that it is actually a fairly good product. If I could get it for $2, I would buy it. If not, I would wait for the next buy one, get one free sales for Techron. They seem to come every few months. Two bottles for around $6.30.
Linked below is a related thread.
Quote from thread,
"The objective of fuel cleaners are to remove materials that are not dissolved by gasoline. Otherwise, gasoline would remove the material.
A solvent "dissolves" by forming a solution. If a solvent is miscible in gasoline, it must be similar to gasoline. The solvent may be able to dissolved the target material (the gunk) on its own. However, once in the fuel, the general characteristics of the fuel is not changed much. Gasoline is an excellent organic solvent already! To make the fuel have the characteristics of the added solvent, the percentage of solvent must be fairly large.
A detergent works very differently. As a general rule, detergents are molecules that have dissimilar ends. One end is hydrophylic (water loving) and the other end is hydrophobic (in this case, gasoline loving). Fuel detergents have the ability to 'dissolve' materials that are not dissolved by the gasoline. When the detergent encounters a material that can be dissolved in a more polar (charged) solution, the hydrophylic end of the detergent molecules group together to create a microenvironment that is "water like". Inside this environment, a solute can be suspended in fuel. This phenomenon can occur with relatively small amounts of detergent. The general characteristics of the fuel does not need to be changed. "
http://theoildrop.server101.com/forums/s...true#Post303060
