Thought I would start a new thread just for SM vs. SJ debate.
Hate to keep beating the dead horse. Like all "quests for the best", it often leads to "most oils will work well, regular maintenance is the key".
My question to Shell's question center/site:
My owners manual for my 2007 23hp Kawasaki air cooled commercial ZTR mower engine recommends and prefers 30wt. SG,SH,or SJ oil. Your site says that SL or SM are "better". Would one of these in a standard auto 30wt. oil be better than SJ Rotella?
Does SM still protect a hot running air cool engine as well as SJ?
"API SM and SL oils are "better" for those applications in which they are required, such as later model cars designed specifically for their use. They are also "better" than older SG, SH and SJ oils produced when those specifications were current, because the base stocks and additives are better. They are also "better" in that they may be used for the older specifications.
There would certainly be nothing wrong with using API SM or SL oil in SAE 30 for your equipment. However, Shell Rotella T Oil SAE 30, which also fully meets your equipment requirements (although only rated to SJ and earlier), would be an excellent choice. Because the product is also rated for diesel engines, it contains high levels of zinc-based anti-wear additives, as well as higher levels of detergents and over-based (TBN) additives, compared to gasoline-only SM and SL oils. Frankly, for your application, when the product is available, I'd choose Shell Rotella T Oil SAE 30".
XXXXX XXXXXXX, Staff Chemist, Shell Lubricants US Technical Information Center
