Hi everyone, my Honda is almost at 60k miles and almost 3 years old. Next weekend I am going to change brakes and bleed the brake fluid with DOT 4. After doing some research I found out that to avoid rusting and future repair of brake components it is recommended to change brake fluid every 2 years or so. Right, this makes sense because brake fluid is hygroscopic - absorbs water, and I’m sure most of us know this already. Anyway, bear with me.
When my car reached about 25k miles the clutch started squeaking, and it was getting so loud that it became really annoying. Again after doing some research I found out that my clutch fluid is the same as brake fluid. So I had some rust accumulated on clutch components. I am not sure about other car manufacturers but I have read stories about Honda owners having costly repairs done at approximately 70k miles due to this problem. I went and bled my clutch right away, the squeak was gone clutch became very smooth. And now the squeak is back at 58K miles. Therefore I think that flushing clutch fluid is as important.
Any opinions, help would be appreciated. Can this be done as preventative maintenance?
Thanks
Dave
Thanks
Dave
