My 2001 AWD CR-V is now due for the rear differential Oil Change. So I went to the local Honda dealer to get the correct "Honda Dual Pump Fluid", but this time, the dealer also gave me the AC Delco Limited Slip Differential additive and said that I add the entire bottle (3.85oz) to the 1 liter of Dual pump fluid when I change the Oil.
Now this is the first time the dealer is advising to add this LS additive to the Honda fluid and in the past I have changed the fluid approx 4 times and never added any LS additive to the fluid.
Is there any harm is adding this additive to the Honda fluid? Will it do any good/bad to the differential? Any suggestions????
TIA.
TIA.
