Pennzoil Platinum 5w20, 03 Honda, 7.8k miles
Spaces no longer have the same width as charaters, so I have to use tabs to format this page. All my old posts (over a year ago) just had spaces and formated correctly inside the 'code' tag. Do a search on my name to find them.
Pennzoil Platinum SM Synthetic 5w-20
03 Honda Accord EX, manual 5 speed with 2.4L 4 cylinders VTEC DOHC engine.
BlackStone Labs.
Oil had 7,794 miles, 26 weeks, 278 miles/week
Makeup oil: 0.
Car had 66,714 miles, 4 years.
Honda recommends 5w-20 oil at 10k miles or 1 year for "normal" driving and at 5k miles or 6 months or "severe" driving for my 4 cylinders engine. My driving is considered "normal" by Honda's definition.
VOAs
Pennzoil Dino 5w20 VOA, dated Januarys 2003. M1 0w20 VOA, dated April 2003.
Pennzoil Synthetic SL 5w20 VOA, dated June 2003.
Pennzoil Platinum 5w20 UOA, dated June 2005.
UOAs
Pennzoil Platinum Synthetic with 8k miles on oil dated Dec 2005.
No UOL for Pennzoil Platinum Synthetic with 8.1k miles on oil, dated Sep 2006
Right numbers are this Pennzoil Platinum 5w20 UOA.
All comments are welcome. Thanks.
VOAs Pennzoil Platinum is different lab.
Code:
Syn SL Platinum
Brand: Penn M1 Pennz Pennz
Weight: 5W20 0W20 5w20 5w20
Aluminum 1 2 0 1
Chromium 0 0 0 0
Iron 1 2 1 2
Copper 0 0 0 2
Lead 0 0 0 1
Tin 0 0 0 0
Molybdenum 186 67 38 47
Nicke 0 0 0 0
Manganese0 0 0 9
Silver 0 0 0 0
Titanium 0 0 0 0
Potassium0 0 0 0
Boron 68 198 0 12
Silicon 3 3 2 3
Sodium 1 7 1 2
Calcium 1856 2892 2149 2301
Magnesium 5 21 18 9
Phosphorus 672 862 728 707
Zinc 785 979 942 772
Barium 0 0 0 0
vis sus@210 2.4 54.9 55.9
Flash point 445 470 430
TBN 7.0 ~12 8.7
UOAs
Code:
Syn SL Plat Plat Plat
Brand: Pennz M1 M1 Pennz Pennz Pennz Pennz Pennz
Weight: 5W20 0W20 0w20 5w20 5w20 5w20 5w20 5w20
Unit Miles: 14.5k 21.5k 29.1k 36.3k 42.8k 50.8k 58.9k 66.7k
Oil Miles: 6.8k 7k 7.6k 7.2k 6.5k 8k 8.1k 7.8k
Oil Weeks: 12 13 14 18.5 32 35 40 28
Miles/week: 566 535 542 386 203 228 204 278
Day: Oct 11 Jan 9 Apr 16 Aug 23 Apr 4 Dec 5 Sep 9 Mar 27
Year: 2003 2004 2004 2004 2005 2005 2006 2007
Oil Filter: Honda Honda M1-104 M1-104 M1-104 M1-104 M1-104 M1-104
Aluminum 9 6 5 5 4 4 - 4
Chromium 1 1 1 1 1 1 - 0
Iron 14 8 8 5 7 6 - 6
Copper 7 3 2 2 1 1 - 1
Lead 1 1 0 1 1 0 - 0
Tin 0 0 0 0 1 0 - 1
Molybdenum 26 89 80 145 65 50 - 49
Nickel 0 0 0 0 0 0 - 0
Manganese 0 1 0 0 0 0 - 0
Silver 0 0 0 0 0 0 - 0
Titanium 0 0 0 0 0 0 - 0
Potassium 0 0 2 1 0 2 - 0
Boron 54 126 125 37 9 10 - 2
Silicon 27 13 7 8 6 7 - 4
Sodium 4 5 9 5 4 2 - 8
Calcium 2088 2939 3074 2255 1922 2477 - 2305
Magnesium 6 13 14 7 22 13 - 12
Phosphorus 818 781 797 748 740 730 - 649
Zinc 900 928 946 791 849 891 - 775
Barium 2 1 0 0 0 0 - 0
vis sus@210 55.6 54.6 56.8 51.5 53.4 54.4 - 52.8
Flash point 400 380 395 370 385 355 - 370
TBN 2.8 5.3 6.0 5.5 ? 3.1 - 4.1
Fuel
Antifreeze 0.0 0.0 0.0 0.0 0.0 0.0 - 0.0
Water 0.0 0.0 0.0 0.0 0.0 0.0 - 0.0
Insolubles 0.1 0.3 0.3 0.3 0.2 0.3 - 0.2
Notes:
Air filter was change at 28,641 and 55569 miles,.
TBN of Pennzoil dino VOA may be old method.
Honda oil filters were Honda's USA (Feltell) larger 80mm diameter oil filter, P/N 15400-P0H-305
Spaces no longer have the same width as characters, so I have to use tabs to format this page. All my old posts (over a year ago) just had spaces and formatted correctly inside the 'code' tag. Do a search on my name to find them.
Anyway, all comments on the UAL are welcome.
The Molybdenum for the 2003 UAO was 326. It was high because the engine still had Honda's bread-in oil. The 3 got lost in the reformating.
Nice numbers! Any fuel economy difference between the 5w20 PP and 0w20 M1? I wonder if M1 would do as well? Your early runs were with a fairly new engine in winter temps, and the formulation of M1 has changed(maybe for the worse). On this latest run, I assume it was mostly short trip driving, amazing! I think you could easily take this oil to 10K especially with summer coming on. I suppose you like to change it every 6 months. Even 1 year/15k is not out of the question, your wear metals would be at Al=10 ppm, Fe=12 ppm or maybe less. You could pull samples from the dipstick at 8K, 11.5K, and then at 15k when you change it out or just do one at 7.5k and another at the end. Or you could just keep doing what your doing, which should keep the engine running strong for about 600k.
Dennis
Thanks,
The engine may last 600k but I don’t think the rest of the car will.
I started commuting to Boston about 3 months ago. It is about a 25 mile commute each way but sometime the traffic has a lot of stop and go. Before that, my commute was only 2.5 miles each way to the train station with longer drives on the weekend. So this run had the first half with very short trips and the second half with longer trips with sometime traffic. I think the short drives for the Dec 2005 UOA is why it had so much fuel in the oil at that time.
The previous 3 UOAs runs had very short trips 3 times a week with longer drives other times. The first 3 UOAs had a 150 mile trip twice a week with short drives the other days.
It is hard to say if the oil changes the gas mileage. I get 34 on the highway but in winter with my snows tires on I get around 27 of mix driving, sometime less.
I'll think I'll take it around 8.5 k next time but I don't like to change the oil in the winter.
If you get a sample pump from Blackstone ($25) you can monitor the oil at 7.5k intervals and maybe just change it once per year (if you only drive 15k per year). The fall is the best time to do this so the oil is fresh for the winter beating and then when the oil is ready to thicken a little you're into the summer when the oil is less subject to fuel dilution and no cold startups so wear is probably minimal. Maybe do your next change in October and then see how it looks in the spring, you could try the Mobil 1 EP or Amsoil if you're worried about going more than 10k. Watch for my UOAs, I am sure your Honda will do as well or better than my Toyota. I have read here that the Fram Air filters help with fuel dilution in the Hondas, have you tried them?
Dennis
Hi Mike,
The comment below is from the following thread:
http://theoildrop.server101.com/forums/s...true#Post792247
Gene K said:
"Yes, Terry [Dyson] likes a simple Fram Air Filter Element as the Filtechs extra restriction can "trick" the ECM into running to rich."
There are many comments about Terry preferring simple paper air filters in cars with fuel dilution especially Honda V6s. You have a four cylinder and it seems there was fuel dilution on three of your analyses, sometimes this is because of driving in stop and go conditions. You might want to try a paper filter. The fuel dilution did not hurt your wear numbers, but you don't want to extend your oci with fuel dilution issues.
Dennis
This is great news for me. I have the 2005 version of the 2.4 in my CR-V and I use this oil now. I think I can be confident with 7.5k/one year changes on this engine now.
Triple, you're correct. This engine actually does show great results on any oil.
I'll think I'll just keep the oil change between 7.5k and 8.5k and not worry about it.
I had some problems formatting this post so I've had an error with the header. I've just checked and the Aug 2004 change was also with dino oil and the Apr change was with Penn Syn SL. You can check the link to the older uoa.
I've got good UOAs for the two times I've used dino oil when you consider the engine was still breaking in on the first UOA.
Quote:
Mike you ever consider going 5w-30 instead of 20...I think 30 would give you less wear. I dunno
His wear numbers are excellent! At this rate the car should go a million miles though the car might be falling apart.
Also honda recomends 5w20, and I may get less gas millage with 5w30
Quote:
Hi Mike,
Dennis
Hey dennis,
I am coming up on an Air filter change. Based solely on the fuel dilution issue, do you think I should try a Fram air filter for an 06 V6 and not an I4? Right now, I got replacement #1 honda OEM air filter in there and that's all I have had for the life of this car so far. What do you think?! Anyone? I am pretty sure an aftermarket air filter is going to work better for the air filter but the same cannot be said, obviously, for the cabin filter or even oil filter.
