Did you get a TBN?
From what I read a while back, Delvac 1 was going to be re-formulated with a lower TBN and lower levels of additives. This was for compliance with modern engine requirements.
The thought was that it would provide excellent levels of performance for less miles. So, extended drains must be tracked via analysis as the TBN would be lower throughout the oil's life.
By the way, I am disappointed as this oil used to be spectacular for motorcycle use. I suspect it will now be marginal. Probably a group III too.
Chris
