Well, he gave you a wrong number. The 1662 NAPA (51662 WIX) is a canister hydrualic filter.
The 51515 (WIX) 1515 is the one to go with from NAPA. There are bigger filters that you can surely fit, but they're typically not of as fine a filtration by Wix reported performance numbers.
1773
zoom
Part Number: 51773
UPC Number: 765809517738
Principal Application: Ford Trucks, Massey-Ferguson Tractors, Oliver Tractors, VW Eurovan (93-95)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.982
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 225
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 30
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Part Number: 51714
UPC Number: 765809517141
Principal Application: Fiat-Allis, Ford, Kubota, Lamborghini Tractors
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.605
Outer Diameter Top: 4.282
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Nominal Micro Rating: 28
Gasket Diameters
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Nominal Micro Rating: 19
Gasket Diameters
Now if he meant a 1762 then here it is
Part Number: 51762
UPC Number: 765809517622
Principal Application: Kohler and Onan Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.529
Outer Diameter Top: 2.966
Thread Size: 3/4-16
Burst Pressure-PSI: 200
Nominal Micro Rating: 25
Gasket Diameters
Attached 2.865 2.421 0.217
