According to the Van Norman #12 manual...Cutter head uses a special "Van Norman
Lubricant".
Also Ram and Feed Gear boxes..."use a good grade of oil having the
following specifications:
API Gravity: 23
Flash OC deg F: 450
SU Viscosity at 210 deg F: 73
Pour Point deg F: 0 "
Any one know what these translate to in today's vernacular?
Thanks
Dave
Hillsboro, Ohio
Lubricant".
API Gravity: 23
Flash OC deg F: 450
Thanks
Dave
Hillsboro, Ohio
