Just wondering if anyone knows for sure whether the AC Delco's will be becoming the Ecore; and if so, has anyone spotted any yet?
Quote:
What are your obstaining reasons?
Quote:
When I see a major filter manufacturer using the e-core design (Puro, Wix, Fram), then I'll reconsider.
Quote:
OK, one of those would be me.
Not until more manufacturers switch over.
Unitl then, I'll stick with tried and true.
Quote:
I already switched to NAPA Gold from www.fleetfilter.com because all you have to do is take a FramTG, AcDelco and Napa Gold and look at them nest to each other and it will take you about 10 seconds to see the Wix NG is better constructed. Plus at fleetfilter it is the least expensive. It's what I call a No Brainer.
Quote:
Quote:
I thought that Napa Gold's where WIX filters?
When I was a Napa sales rep they were. It was 8 years ago I left but doubt that relationship has changed.
Quote:
I also do not like that Champ Labs added that additional plate that evidently assists in threading the filter on. The holes in the add on plate do not line up with the holes in the filter end plate. What's up with that?
