Here's a VOA on Shell Rotella T 10W-30 CJ-4 API SM:
Code:
Aluminum 0
Chromium 0
Iron 1
Copper 0
Lead 0
Tin 0
Molybdenum 0
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 29
Silicon 4
Sodium 3
Calcium 1944
Magnesium 6
Phosphorus 893
Zinc 1008
Barium 0
Sus@210F 64.8 should be 59 - 66
FlashInF 425 should be > 400
Fuel% - should be < 1.0
Antifreeze% - should be 0
Water% 0.0 should be 0.0
Insolubles% 0.0 should be < 0.7
TBN 10.8
Blackstone Comments: Blackstone Comments: This oil has a starting TBN of 10.8, which is about as high as any type oil we know of for a 10W/30. Apparently this oil has a diesel engine rating to start out with a TBN this high. The viscosity was strong for a 10W/30 when checked @ 210ºF. This oil was found to be clean and dry and it should serve your engine's needs well.
My Comments: Got this mixed 4 qt.'s + 1 qt. of Pennzoil Platinum 5W-20 in both my moms and brothers 3.8L Ford's...oil pressure comes up nice and quick in our cold Chicago climate. I'll probably do a UOA on one of them at some point, except they both put so few miles on it'll take forever for their next oil change, and the results will be skewed due to Ford's cr@ptastic head gasket design on these engines....
Enjoy All!
Chuck
Code:
Aluminum 0
Chromium 0
Iron 1
Copper 0
Lead 0
Tin 0
Molybdenum 0
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 29
Silicon 4
Sodium 3
Calcium 1944
Magnesium 6
Phosphorus 893
Zinc 1008
Barium 0
TBN 10.8
Enjoy All!
Chuck
