ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
104 registered members (240_Ed, 28oz, aquariuscsm, atikovi, A310, 12 invisible), 1,750 guests, and 39 spiders.
Topics295,013
Posts4,926,011
Members66,664
Most Online2,553
Oct 27th, 2018
Page 3 of 5 1 2 3 4 5
Re: I need the best penetrating oil [Re: Throckmorton] #1074863
01/29/08 11:40 AM
01/29/08 11:40 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
I used the wax trick once - it worked great!
Re: I need the best penetrating oil [Re: Kestas] #1082737
02/09/08 08:44 PM
02/09/08 08:44 PM
Phoenix, AZ
Thordom Offline
Thordom  Offline
Phoenix, AZ
Re: I need the best penetrating oil [Re: Thordom] #1084244
02/11/08 09:50 PM
02/11/08 09:50 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
I have used both Mouse Milk and Kroil both at work and at home.
IMHO, Mouse Milk is better for dissimilar type metal corrosion than Kroil. In cars with steel on steel corrosion, Kroil is better.
Hootbro
2018 RAM 2500 Cummins 6.7L (Delvac 1300 15W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: I need the best penetrating oil [Re: gtx510] #1132750
04/19/08 01:13 PM
04/19/08 01:13 PM
Moscow
Konst Offline
Konst  Offline
Moscow
HUSKEY RUST RELEASE - An extra-heavy-duty penetrating fluid formulated with a unique synthetic wax to penetrate into rusted, corroded or frozen parts to ease break-out. It displaces moisture, leaving a long-lasting wax-like lubricant and protective film. Also available in bulk form.
http://www.huskey.com/ProdInfo/Rust%20Release.pdf
Re: I need the best penetrating oil [Re: Konst] #1134290
04/21/08 08:18 PM
04/21/08 08:18 PM
ohio
mcshooter Offline
mcshooter  Offline
ohio
i have use pb, kroil and just found sea foam deep creep and used it to remove carbon from pistions i took out of a 90,000 mile engine and it did a great job. so give it a try on rusted bolts
Re: I need the best penetrating oil [Re: mcshooter] #1215441
08/13/08 07:05 PM
08/13/08 07:05 PM
NC
jtl Offline
jtl  Offline
NC
Schaeffer Penetro 90 is hands down the best I have used. Kroil and PB work but penetro is amazing. I have been a Plant Engineer for 36 years and I have tried most.
Re: I need the best penetrating oil [Re: Maximumcanon] #4447831
07/02/17 08:17 PM
07/02/17 08:17 PM
Park City, Utah
JeromeBrown70 Offline
Park City, Utah
Kano Kroil is always my number one choice. You can refer more here: What Is The Best Penetrating Oil?
Re: I need the best penetrating oil [Re: Maximumcanon] #4447843
07/02/17 08:32 PM
07/02/17 08:32 PM
Oneida County, NY
rsylvstr Offline
rsylvstr  Offline
Oneida County, NY
Agree. Aero kroil
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: I need the best penetrating oil [Re: jtl] #4447852
07/02/17 08:48 PM
07/02/17 08:48 PM
PA
MarcS Offline
MarcS  Offline
PA
Agreed. Didn't find kroil to be that much better than liquid wrench to justify the expense and hassle to get it. Penetro is something else though. Whatever is in that can is magic.
And to the OP, you can buy penetro on amazon for about $11 a can shipped.
Re: I need the best penetrating oil [Re: Maximumcanon] #4447950
07/02/17 11:16 PM
07/02/17 11:16 PM
Tug Hill, NY
Corelokt Offline
Corelokt  Offline
Tug Hill, NY
If it can be, it's best to use a rust removal method. There are the soaking solutions and electrolysis. Another thing that helps is vibration. Strap an old electric toothbrush to the part or something like that and use a penetrant. I've used those methods with good success.
86 CUCV. 6.5L. Level-3 4L80. NP205. 9-16 14 ply tires, HX35/40 turbo. WMI. 5" exh. ARP studs heads & crank. Cooling upgrades. Rattle can camo.
Re: I need the best penetrating oil [Re: Corelokt] #4500253
08/28/17 09:45 AM
08/28/17 09:45 AM
Herrin, Illinois
CharlieW618 Offline
CharlieW618  Offline
Herrin, Illinois
Acetone and ATF mixed 50/50.
Formally Charlie1935
Du Quoin, Il.
Re: I need the best penetrating oil [Re: Maximumcanon] #4505103
09/02/17 06:02 AM
09/02/17 06:02 AM
Illinois
dave munson Offline
dave munson  Offline
Illinois
My vote with Kano Kroil. Midway USA carries the can. It did things in 1 minute pb could not in a week. I am going to look up Schaeffer Manufacturing Co. 0190-011S Penetro 90 at amazon because I ... I have to.
dem
Re: I need the best penetrating oil [Re: Maximumcanon] #4507362
09/04/17 03:15 PM
09/04/17 03:15 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
Schaeffers penetro 90 is an excellent penetrant and very versatile with triple rust inhibitors as well.
High quality Specialized Lubricants pay for themselves!
Re: I need the best penetrating oil [Re: Maximumcanon] #4507762
09/05/17 03:40 AM
09/05/17 03:40 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
I like 50/50 ATF and Kerosene
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: I need the best penetrating oil [Re: SnowDrifter] #4508517
09/05/17 08:52 PM
09/05/17 08:52 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
Schaeffers penetro 90. it gets my vote,,much better than pb or 3in1.
