Regarding oil spec sheets, what does this number mean in the real world?
Quote:
Sorry for deviating but I have always wondered if police spec'd cars have great handling,sporty tight suspension .Is it true.How does your car handle.
This was posted by a guy on this site (I do not remember the name)
Xw-20, Xw-30, Xw-40, etc (HOT!)
This is your oil's hot viscosity. The viscosity is measured @ 100c.
This number is relative when the engine is warmed up.
The most common unit is cST. The larger the number, the "thicker" the oil.
Examples
A "30" weight is between 9.30-12.49 cST @ 100c.
A "40" weight is between 12.50-16.29 cST @ 100c.
Regards
Quote:
Unfortunately, at least in the case of the CVPI, these high rate springs actually decrease the handling ability of the vehicle (this has been confirmed by the Michigan State Police). It does however, increase the longevity of the vehicle, and allows it to ride slightly higher, which is a good thing when you go tearing through a highway median.
Quote:
Very interesting. Explain. I think you mean it makes the tires work too hard allowing the sidewalls to flex too much.
