Well so much for CJ-4 requiring better basestocks.
Rotella T CI-4+ = 100% Group II Basestock
Rotella T CJ-4 = 100% Group II Basestock
Quote:
The reason for that comment is that some 15W-40 HDEOs were using some Group 1.
Quote:
Delo 400 LE states it is made with ISOSYN, however the flash point has dropped from 460F for the CI-4+ version to 399F for the CJ-4 formulation. Same for the Rotella, flash now 400F. Does anybody know what's up with that?
Quote:
CI-4 has higher TBN the new CJ-4 which has a lower around 8 TBN some trucker/companies are leary of the low TBN for long drians and as such CVX will make it for a while till everyone is comfortable with the CJ-4.
bruce
Quote:
.....The manufacturers product data sheet states that the Rotella 10w-30 CJ-4 has a flash point of 249C or 480F. So is that false than?
