Donald, I wasn't referring to pre-heating the engine. The coolant, engine and oil temperatures need to come up to operating temperatures. The washing down of the cylinder I was referring to is basically what Wrench said. The excessive amount of fuel washes the oil off the cylinder walls and the piston/rings and leads in best cases to high oil consumption, or in worst cases causes liner/ring/piston failures. After stating the genset, run it to at least half load, preferably more (around 80%) and leave it there long enough to warm everything up and cook the oil clean of fuel and moisture. I also wouldn't wait long before applying a load, we run our big gens for about 3 minuets before putting a 80-100% load on them. Each gen is started once a week and the transfer switches engaged and we actually operate the buildings as if the power were out for about an hour.
I would not recommend using either to start the engine except as a last resort. Either creates extremely high cylinder pressures and can, if used improperly, bend rods, pop head gaskets, break pistons and other nasty things you don't want to have happen. If you must use either, use it very sparingly.
Another thing to consider is putting the coolant heater on a timer. The trucks I don't drive much are left plugged in year round. In the winter the heaters run for 2 hours every 12 hours which is enough to bring the systems up to temp (or a close as the heaters will get them). Even in very cold weather this is usually enough to let any of them start easily.
Since the weather has been getting colder, have you tried to start the genset with no preheat? And, as it was mentioned you would use some type of winter fuel additive, and maybe a biocide if you aren't going to change the fuel yearly.
