This is my third oil analysis on a vehicle that I’ve owned since new; I welcome any comments. The vehicle is a 2002 Dodge Ram 2500HD Quad Cab with a Cummins 5.9 liter, 24 valve, turbo engine and auto tranny. The truck is driven about 50-50 stop & go and freeway. The truck is not used for towing or racing. The air filter used is a Fleetguard , P/N #AH19004. This is a very large cylinder shaped paper filter that is attached to the air induction tube and sits on a metal heat shield. The oil filter used is a Donaldson ELF full flow with no bypass filtration.
The lab was Oil Analyzers Inc. and their analysis recommendation was no corrective action required, oil is suitable for continued use. Resample at next regular interval
I took this sample at 7,500 miles which coincided with the previous change intervals prior to oil analysis. There are several items that puzzle me and make me wonder how accurate oil analyses really are. First of all, the iron number stayed the same but the lead number dropped; frankly I would have expected the number to stay the same or go up. The copper number went up 56% - I’m really puzzled by that. Aluminum went to zero and silicon went up 150%. I have examined my air filter set-up and everything appears normal so what’s up with this increase. Finally, the viscosity at 100° C went up but the oxidation number decreased 65%.
I’m speculating that the analyst at OAI (same person did previous sample) had too many analyses to do or the equipment was malfunctioning. It may be time for another analysis company.
SAMPLE MILES 7,513 5,052
VEHICLE MILES 45,997 43,536
OIL USED AMSOIL AMSOIL
AME 15W-40 ;AME 15W-40
SAMPLE PERIOD 05/14/06- ;05/14/06-
10/25/06 ; 08/19/06
AMBIENT TEMPS 39° to 106°;69° to 106°
MAKE-UP OIL NONE NONE
IRON 18 18
CHROMIUM 1 1
LEAD 4 5
COPPER 14 9
TIN 0 0
ALUMINUM 0 2
NICKEL 0 0
SILVER 0 0
SILICON 5 2
BORON 1 1
SODIUM 0 0
MAGNESIUM 22 17
CALCIUM 3805 2888
BARIUM 0 4
PHOSPHORUS 1190 1265
ZINC 1520 1462
MOLYBDENUM 0 0
TITANIUM 0 0
VANADIUM 0 0
POTASSIUM 0 0
FUEL (% VOL) VIS @ 40C , cSt NA NA
VIS @ 100 C, cSt 13.34 12.85
WATER 0 0
SOOT/SOLIDS (% WT)0.1 0.1
COOLANT NO NO
TBN 9.75 10.27
OXID 15.0 23.0
NITR 4.0 4.0
F-SOOT 0.01 0.01
10/25/06 ; 08/19/06
IRON 18 18
CHROMIUM 1 1
LEAD 4 5
COPPER 14 9
TIN 0 0
ALUMINUM 0 2
NICKEL 0 0
SILVER 0 0
SILICON 5 2
BORON 1 1
SODIUM 0 0
MAGNESIUM 22 17
CALCIUM 3805 2888
BARIUM 0 4
ZINC 1520 1462
MOLYBDENUM 0 0
TITANIUM 0 0
VANADIUM 0 0
POTASSIUM 0 0
WATER 0 0
COOLANT NO NO
TBN 9.75 10.27
OXID 15.0 23.0
NITR 4.0 4.0
F-SOOT 0.01 0.01
