Methanol is really cheap, and has such a high octane rating that you can use it with a very high compression ratio, which is more efficient. The big problem is that it doesn't evaporate at low temperatures, so a regular engine simply wouldn't start on a cold day.
What if you had an insulated tank of maybe 2 gallons of hot coolant stored under the hood that could be circulated to preheat the heads before starting? I've read about this idea as a way to reduce cold start emissions, but maybe it could be adapted to run an engine on straight methanol. The tank could be a vacuum insulated container, with a heating coil inside so you can plug it in, incase you don't run the engine for a week or more, and it cools off.
