Thanks molakule.
My theory on this is it is a waste of money to use any filter other than designed for the engine. Using a larger oil filter will increase the oil capacity, but the oil will still heat to the same temp, just take it longer to do it. Also once it is hot, the increased capacity takes longer to cool down.quote:
Originally posted by sbc350gearhead:
Would a larger oil filter also help lower temps?
Jason,quote:
Using standard engineering units, flow changes from laminar to turbulent above a Reynolds number of 2100, or maybe by 3000. R the Reynolds number equals pipe diameter X velocity X density divided by the viscosity. The 2 easiest things to change would be the velocity and viscosity. You could add a higher volume pump, and use thinner oil.quote:
Originally posted by Not the Autorx Frank:
How can you create turbulent flow? I know thinner viscosity will become turbulent more easily. Short of redesigning the engine, what else could you change? Snip....
A lot of heat is picked up, actually generated by shear, in the journal bearings.quote:
Often it is a challenge coming up with all the data you need to do pipe flow calculations. An average diameter for the oil passages in your engine would be a good one.
Where does the oil absorb the heat from the engine? In the passageways where it might be turbulent, or other, slower moving places? I wonder if that is what the big puddle of oil on top of the head on my truck is for? It is designed so the oil stands about a half inch deep before flowing down to the pan.
This may be apples to watermelons, but in a car that has been outside at -30 for several hours, can anyone think of what spot of the engine would be best to 'zap' with a torch of some sort to help the engine heat up?quote:
Originally posted by MolaKule:
Using heat conduction theory, it says that heat energy will flow from the hotter object to the cooler object.
Here, the cooler object would be the jacket around the liner which has the circulating coolant which would be at a lower temperature than the oil. So heat is flowing from the oil film to the jacket in fully warmed-up engine at operating temperature.
