I have a 1984 VW Rabbot L diesel. My owners manual states to use a CD rated oil. I am doing a oil change later today. I have been so for using any good 15W-40 HDEO that I had at the time in my garage for the previous oil changes. Which have just been two. This is the first winter I have owned this diesel and have had great luck with the plain old 15W-40. Even on a few of those 0 degree F days hated to put white lighting through that but without fail she has always started and ran. I was looking at a lighter oil to put in her at the next oil change for the cold startes I have been seeing. I was thinking of RTS 5W-40, M1, D1, and other syns. Well I have ten quarts of Mobil Clean 5000 5W-30 in my garage. I am not sure where or when I bought it but its there. I was using it in my snowthrower and noticed it is CF rated. I was thinking of using it since I have it already. I am planning on a short oci with it. I will change it out at 2K miles probably. I might squeaze it to 3K. But thats the most. I was thinking of sending in a UOA on it. I would like to see how it held up in a diesel. You know that Mobil says it good for 5K or half a year. If holds up great I think I may have found my winter oil. What do you guys think? If my sample comes back good I will use it again and may go longer on it and see how long it is good for. I am thinking that my diesel will be a good test on this oil. Since it is marketed for the gas market and is rated for cf diesel. I will be putting it in tonite.
KC
KC
