Well, for the GC, the only reason I have a stash is the green is no longer made, so I wanted a nice supply of it. If I knew the green was going to be around for a while (or the gold is as good or better) I would not buy like I have.
Unless they stock it from the front. At one store, the more I took off the shelf, the older it got. M0507 at the front, then M04, and M02 at the very back.quote:
Originally posted by TxGreaseMonkey:
Notice AZO, with their inclined shelves, has a great gravity feed FIFO inventory system.
Exactly, it depends on the configuration of the store, if they have access from behind and stock from behind, it would be FIFO. But, most stores I have been in (well over 30 stores in my area) either don't have access behind the oil display or don't stock from behind (particularly as the Castrol 0W30 was on the top shelf and rear portion of the shelf is higher than the front) and would therefore be LIFO.quote:
Originally posted by eliminator: Unless they stock it from the front. At one store, the more I took off the shelf, the older it got. M0507 at the front, then M04, and M02 at the very back.
