Assuming that the best equipment is more likely to give the best results the first time. What machine should I ask my local auto shops if they use?
Absolutely. I was having vibration issues with a new set of tires on a car last summer. I finally did some research and discovered that Hunter balancers were highly recommended, and I called around and found a tire shop close by with a Hunter machine.quote:
Originally posted by Surprise:
Thanks for all of the advice!
One more question though. Would asking a tireshop what model of equipment that they use be reasonable?
In the old days, shops used to advertise (such as in the Yellow Pages) what brand of equipment they used, so it certainly would be reasonable to ask. Those who invested in good equipment should be happy to tell you about it!quote:
