How do you keep an oil filter cap wrench from slipping/turning on the filter? I didn't tighten the old one that much, and had no trouble getting the previous one off, but this one kept slipping/turning over the notches on the filter.
I ended putting a couple of pieces of duct tape in a cross pattern across the top of the filter to create some grip. That worked in removing the filter, but then I couldn't hardly get the dang wrench off the old filter!!!
I was using language that should normally be used only at a drunken sailor's convention...or perhaps at one of my family reunions (Yeeeee, Hawwwww!!!)
Any ideas, thoughts, suggestions, or words of encouragement are welcome!!!
