This is what I found on another forum. I don't know if this information is correct.
___________________
A open deck means basically the cylinder sleeves are seperate from the block at the head. This is done for a number of reasons, not the least of which being cost. Open blocks are cheaper to produce than closed blocks. Additionally, some argue that open blocks cool better, however this is definately debateable.
An open block can suffer from cylinder "walk" in high power applications, and therefor many people "close" the block to ensure the cylinders stay aligned. Closing the block involves designing a plate that can be welded into the block around the sleeves.
Closed blocks are solid on top of the block with only coolant passages. Thus the cylinder sleeve is connected to the block at both the top and the bottom on a closed block, and only the bottom and perhaps the middle on a closed.
It is terribly popular to close the block on a honda if one decides to make any amount of power. As for the infiniti, i have no experience, and cannot speak to the power levels it can hold.
___________________________________
Regards,
