Gave my '94 Geo Metro a much overdue coolant change last night. The manual says it holds 4.1 L of coolant, but when I drained the rad I only got about 2 L out so I assume the rest was in the engine. I refilled it with water, idled for about 5 minutes (had heat set on maximum inside), let it cool, then drained the water. Did 3 rinses total... after the 3rd, the water wasn't totally clear but it was just very slightly green so I figured I'd gotten most of the old coolant out of the engine.
Here's the question. I refilled the rad with about 70/30 antifreeze/water. After some thought though, if what's in the engine after those flushes is close to pure water, and the engine holds as much as the rad (2 L each), I'm going to end up with around 35/65 after it all mixes together, or maybe 40/60 if we assume there's still a little coolant in the engine. That seems pretty low, I was aiming for 50/50. Am I in trouble? It rarely goes below freezing here so reduced low temperature protection is no big worry, but I may regret not having all the anticorrosion etc stuff from the coolant. No big deal? Or should I get more antifreeze in there? I'm using some lovely bright green Motomaster 8 Metal "advanced silicone silicate formulation" coolant.
