The Prestone Extended Life is, from what I have learned at this forum, a Dexcool clone and is ok to use in your engine because your Cummins is not wet-sleeved. I service a 1997 GM diesel van and it has always had Dexcool in it and so far, after 200000 miles, there has been no cooling system problems. Diesel engines with wet sleeves will need nitrites, which G05 has and Dexcool doesn't. I sense that you are keen on switching over to a OAT coolant.
