quote:
Originally posted by Oldswagon:
Thanks for the advice so far. I should probably explain a little further though.
The car that I plan to flush is 20 years old and the cooling system should probably be chemically flushed. The system is still all original (other than the hoses) and is starting I am starting to notice deposits in the rad. Winters are pretty harsh here, so cooling system peformance is critical. As I said, I have used chemical flushes in the past without any issue. However, I would like to find a better flush to ensure that my rad, coolant passages and heater core are as clean as possible.
Here's what I do for a first time flush in a vehicle with a few miles on the clock...
Buy many gallons of distilled water.
Buy two little jugs of Prestone Super Radiator Cleaner (NOT THE FLUSH!).
Basically, drain all the coolant from the radiator (using the tap on the bottom of the radiator) and fill it back up with distilled water. Run the engine until you fill the upper hose turn hot, and then drain the radiator again, and again fill up with distilled water. Continue to do this until the liquid flowing out of the radiator drain is clear.
BTW, make sure when your doing the routine that you have your heater on so you get the stuff out of the heater core as well.
Anyways, once the system is full of clean, distilled water, add the jugs of the cleaner and drive it around for several days (Instructions are on the cleaner bottle).
After the period of time, do the same routine again. Drain radiator and fill with clean, distilled water. Do this until the drain runs clear.
After this, fill radiator with new antifreeze/coolant (pre-mixed stuff is easier to use)...cycle system again, and keep filling and draining until you've put in enough antifreeze to equal the capacity of the system (whatever your manual says).
*This might sound complicated (or confusing), but it's very simple, and will leave you with a spotless coolant system.
[ September 04, 2003, 05:42 PM: Message edited by: Jelly ]
