With two Frantz bypass filters installed in the engine bay where the battery used to reside the surrounding electrical wires are getting a lot of heat from them. These wires were designed to be near a battery that generated no heat. Occassionally the smell of plastic burning will intrude into the car which I became so familiar with my previous car '91 Civic.
What is the best way to protect the wiring from burning heat? Will insulating the wiring work? If so, what would be the best insulation material?
Or let more air from outside flow into the engine bay for cooling by installing a scoop on the engine hood or some kind of air duct; but can this be done without introducing rain/water into the engine bay that will harm the electrical/electronic components of the engine? Has anyone done this sort of modification? If this is doable, I will probably as a body shop professional to install it.
The insulation method will provide some protection to the wiring when car is in idle. It is more like a passive protection. Using air flow is an active way to reduce the heat but only when the car is moving. Any other suggestions?
