quote:
Originally posted by instigator:
i have sent a PM to ralph about his modifications to the motor guard air filters to accept oil but had no response. so now i'll ask those of you that have this filter setup.
"Ralph Wood"
Instigator,
Only someone like me would bring back the Motor Guard submicronic bypass filter as a lube oil filter when Motor Guard gave up on selling lube oil filters 25 years ago. Motor Guard has found happiness in making the very best compressed air filters available. I was a dealer when all they had was lube oil and fuel filters. The name didn't come from compressed air filters. I'm not profit motivated. If I break even at the end of the year it's been a good year. Big companies like Mc Master-Carr can get a better price than I can.
For lube oil or fuel I must remove the polypropylene seals and install CNC machined Dupont Delrin seals. They are known as cores. T.P. needs longer cores to support the T.P. core to keep the oil pressure from collapsing the T.P. core. I install a CNC machined aluminum hold down and a 7/16" locking shaft collar. Then I add shipping to the price of the filter.
Motor Guard has always made die cast aluminum filters. I can sell the Gulf Coast 0-1 jr for less because it is ready to go. I'll put the price back on my website. The 0-1 jr is the easiest to sell because the Military buys a lot of them. The Motor Guard is the easiest to service but if you are going to put it in a horizontal position it doesn't matter. The filters don't care what position you put them in.
My sister in law has a Frantz in a horizontal position for the ATF and a Motor Guard tilted for the lube oil. I removed the big windshield washer tank to make room for it. I replaced the tank with a smaller tank. It was a lot easier in the 60's.
I'm converting to the Motor Guard's at work and my personal equipment. My 59 model Frantz I will keep for sentmental reasons. The rest I will sell. I just pulled a perfectly good Frantz off my tractor transmission and installed a Motor Guard M-30. The Frantz filters paid for themselves many years ago. Your engine doesn't care which of the submicronic filters you use. The 25.00 elements work just as good as T.P. if they can filter to 1/10 th of one micron on the first pass. If you don't change the filters as often as you need to the engine won't last as long. You might get a compressed air filter and drive a sleeve down on the stock cores to keep the slick oil from letting the cores slip off the seats. Add 1/4" to 1/8" bushings and a 1/16 orifice. I don't see much reason for me to sell two different kinds of little filters but it might be good to give people a less expensive choice.
Ralph
[email protected]
Reply-To:
[email protected]
To:
[email protected]
Subject: Private Message from: instigator - motor guard filters
Date: Wed, 29 Jan 2003 01:03:00 UT
Private Message Notification
Subject: motor guard filters
instigator just sent you (RalphPWood) a Private Message at BOBISTHEOILGUY.
You are being notified because you have instructed us to send you a notification each time someone sends you a private message. You can disable this automatic notification in your profile settings on the board.
Here is the message sent by instigator:
hi Ralph, i have a couple of Qs about this devise.
1) i see these filter assys on the internet for alot less than what is on the gulf coast site and wanted to know just what you did to these units to warrant the mark up? (humbley asking, not trying to get in your face )
2) can i buy one of these air units and convert it myself? (i know i could, provided i have the info that you posess)
i,m working on a budget here (cut backs and a looming reduction in pay) i know you units are worth every bit that they are commanding, but i just cannot afford the price that they are commanding
3) can these units be mounted in any orientation? i want to mount it on its side onto my frame rail (i have no room in the engine compartment)
thanks keith deas
To view this private message, visit:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_pm&d=H&t=00000761
Message Board:
_________________________________________________________________
[ January 30, 2003, 11:52 PM: Message edited by: RalphPWood ]
