Hong Kong Cage Homes - This is just nuts!
by StevieC
2 minutes 35 seconds ago
Birthday
by Marco620
25 minutes 19 seconds ago
Lee-Enfield SMLE .303 retirement
by Papa Bear
27 minutes 57 seconds ago
Mobil Delvac 1300. $1.76 a gallon until 8/20
by Gasbuggy
47 minutes 57 seconds ago
Quaker State high mileage 5w30 thus far
by bbhero
Today at 07:32 PM
Oil coolers on trucks
by Snagglefoot
Today at 07:32 PM
RTV drying out
by buck91
Today at 07:27 PM
T6 in Outback 2.5
by countryboy9799
Today at 07:16 PM
LIQUI MOLY TOPTEC 4100 0W40 vs REDLINE 10W40
by g60
Today at 06:56 PM
Lubeguard Platinum for track use on a Z4?
by FlyPenFly
Today at 06:44 PM
Oil temperture before going at it (wot)
by turboaccord1
Today at 06:16 PM
2015 Tahoe - Original OEM
by E39LSMO
Today at 05:51 PM
Christopher Watts
by Zee09
Today at 05:35 PM
Video streaming on Vizio smart TV
by Donald
Today at 04:43 PM
Oil Sump Circulation Throughout Engine
by mbacfp
Today at 04:29 PM
The Limits of RA Bargains on Wiper Blades
by khittner
Today at 04:19 PM
Engine oil cleaning ability vs Oil temperature
by magnus308
Today at 03:24 PM
For Canadians: Mobil 1Turbo Diesel Oil Canadian Tire
by Snagglefoot
Today at 03:15 PM
Old School Tires
by UberArchetype
Today at 03:11 PM
Ford 4.6 oil pump pickup
by FastLane
Today at 02:55 PM
kristrees, PetitFrereArmada, Vlad302, JDUram, gtg
65728 Registered Users
86 registered (ADJ, 5AcresAndAFool, 77GrandPrix, 14Accent, 87sammy, 2009Edge, 14 invisible), 1633 Guests and 31 Spiders online.
65728 Members
67 Forums
288829 Topics
#597519 - 05/24/05 06:06 PM WD-40 Uses.....
2004 F150 4x4 Offline
Loc: Bedford, Tx
Guys, I was poking around on the WD-40 website looking at tips and uses for their product. They also had some cool tips that didn’t have anything to do with WD-40 like how to mount a vice on a piece of plate steel and then insert in your truck mounted receiver hitch for a portable vice. Anyway I digress. The question(s) I have concern spraying WD-40 on your windshield wiper blades to keep them from sticking, also using WD-40 to clean bugs off the front of a vehicle and one tip suggested spraying WD-40 all across the front of vehicle to keep bugs from sticking? Has anyone done this? My main concern is that it might damage the paint or plastic bumper on some of today’s cars?
On the windshield wiper blades I have just never heard of this, doesn’t seem like oil and water would mix?
I am going to East Texas this weekend so if the whole “prevent bugs from sticking” thing would work, now would be a time to try it.
Comments, suggestions, ideas?
#597520 - 05/24/05 06:41 PM Re: WD-40 Uses.....
90lsteg Offline
Loc: Ohio
I have never used WD-40 on wipers but have used 303 Aerospace protectant. No more squeaks or streaking. You can check it out here
http://www.303products.com/main.php
Regarding keeping bugs off the paint, would a good waxing before you travel work better?
#597521 - 05/24/05 06:51 PM Re: WD-40 Uses.....
Loc: Bedford, Tx
"Regarding keeping bugs off the paint, would a good waxing before you travel work better? "
Maybe/probably but the allure of the WD-40 is that I could just spray it on quickly and rinse off when I got back home. Waxing is a pain.
#597522 - 05/24/05 06:58 PM Re: WD-40 Uses.....
XS650 Offline
Loc: Northern CA
Windshield wiper blades seem to be made of a fairly low grade of rubber that is intended to not last very long. I doubt that their resistance to petroleum products is very good.
The primary ingredient in WD40 is either kerosene or stoddard cleaning solvent. Probably won't hurt your paint, but no guarantees.
I used to use silicone spray, like the silicone lube in a spray can, on the front of cars before driving through bug country. It worked. Residial silicone can be problem if you want to paint later.
#597523 - 05/24/05 07:15 PM Re: WD-40 Uses.....
JohnnyLock Offline
Loc: Houston, Texas
Do not put WD-40 on wiper blades. I had a co-worker pull a prank do that to my car when I was a kid working construction and the first rainfall made it he** to see. I ended up putting on new blades. I wax my windshield with TurtleWax or use RainX -- the rain beeds up and my wipers don't stick at all.
#597524 - 05/25/05 05:32 AM Re: WD-40 Uses.....
Amkeer Offline
Loc: Florida
WD-40 will deteriorate rubber products over time.
#597525 - 05/25/05 08:10 AM Re: WD-40 Uses.....
wileyE Offline
Loc: Kitsap, WA
I use lemon pledge on the blades and window, also on the plastic front end parts. The bugs do come off easier, 'cept maybe the really juicy ones.
#597526 - 05/25/05 09:27 AM Re: WD-40 Uses.....
Silk Offline
Loc: New Zealand
Our Telecom workers used WD40 for chewing gum removale,the only thing that worked they reckon.I spray my bikes,road and dirt all over with WD40,keeps them looking nice and I get to have fun in the first few corners till it wears off.
#597527 - 05/25/05 09:55 AM Re: WD-40 Uses.....
Blue99 Offline
Loc: Wisconsin
I commonly use WD-40 as a cleaner/degreaser on lawnmowers, string trimmers, chainsaws, etc. It does not harm the paint - the light carrier oil leaves a slightly glossy shine on the equipment.
A large percentage of the formulation is stoddard solvent, which sometimes is labeled as de-odorized kerosene.
An old trick for putting a shine on a car after washing was to add a few drops of kerosene to the rinse water bucket & wipe down thoroughly.
#597528 - 05/25/05 10:21 PM Re: WD-40 Uses.....
Loc: Bedford, Tx
Thanks for all the replies. Looks like it would be safe to hose down the front of my truck with WD-40 before going into “bug-country”. I just wanted to make sure since this truck is only 9 mos old and it is the nicest truck I have ever had.
