I was working on a garbage disposer today, and accidentally dropped a 1/4 in. ratchet in a tub full of water. I disassembled it, dried everything off, and sprayed the internals with Mobil 1 spray lube (in order to displace any remaining moisture, among other things).
Will Mobil 1 lube be enough, or does this application call for something heavier?
Thanks.
Thanks.
