DTD EBay sale
by T4RF. 10/17/18 02:28 PM
My CarHop Experience...
by dogememe. 10/17/18 01:47 PM
Total 10w50 / What is your opinion
by DibroTeam. 10/17/18 01:06 PM
Early Christmas present to me! Air Compressor
by dnewton3. 10/17/18 10:37 AM
Rock Auto 5% off code.
by Sayjac. 10/17/18 09:53 AM
Canada - Marijuana now legal
by Smokescreen. 10/17/18 09:51 AM
Proper sampling
by BigShug681. 10/17/18 09:36 AM
Snow Driving - Engineering Explained
by StevieC. 10/17/18 09:36 AM
Friendly Inspection
by Zee09. 10/17/18 09:33 AM
Shell V-Power NITRO VS "Cheaper" fuel
by Datarock. 10/17/18 09:02 AM
Cut open used Fram Ultra & Subaru OEM
by MrWideTires. 10/17/18 08:31 AM
Cruze diesel oil filter, which one?
by Rat407. 10/17/18 07:17 AM
Kagayaki rice breed???
by RyanHeo. 10/17/18 06:24 AM
Small engine oils
by NHRATA. 10/17/18 12:46 AM
"OEM" Brand Hyundai Coolant/Anti-Freeze
by Gannet167. 10/16/18 11:45 PM
Pentosin Pentofrost A2 vs Peak OET Asian
by tony1679. 10/16/18 11:40 PM
FBM4130, tawas23, wfillier1979, jimmy154, DizzyFrog
66236 Registered Users
98 registered members (anndel, Anduril, badtlc, AzFireGuy79, 53' Stude, 97f150, 7 invisible), 2,193 guests, and 39 spiders.
Topics292,091
Posts4,873,961
Members66,236
Most Online2,494
Oct 17th, 2018
Page 3 of 3 1 2 3
Re: Good Oil for Locks ? #597284
05/07/05 06:16 AM
05/07/05 06:16 AM
Southeastern, PA
04.SPT.WRX Offline
04.SPT.WRX  Offline
Southeastern, PA
I knew a Medeco authorized locksmith several years ago who swore by this stuff:
http://www.super-lube.com/product_description.htm
I have been using it ever since.
Re: Good Oil for Locks ? #597285
05/07/05 06:26 AM
05/07/05 06:26 AM
Cordelia, CA
VaderSS Offline
VaderSS  Offline
Cordelia, CA
Mobil 1 spray works great, if you already have some.
Re: Good Oil for Locks ? #597286
05/10/05 05:33 AM
05/10/05 05:33 AM
Loveland, Ohio
John K Offline
John K  Offline
Loveland, Ohio
Probably not the issue but I've been warned to not use key rings with lots of keys because the weight can wear out the lock, going over bumps etc. Some people have lots of stuff hanging off of their key rings..... Something I never thought of until the Honda service manager pointed it out. He used the criteria that if he could hold the ignition key between thumb and forefinger it was ok.
Re: Good Oil for Locks ? #597287
07/11/05 02:46 AM
07/11/05 02:46 AM
Calgary Canada
Jim 5 Offline
Jim 5  Offline
Calgary Canada
GM Specifically recommends 5w30 on the locks and ignition of my '98 K1500. It's pretty easy to come by. I usually dip my key halfway in 5w30 and then run it in and out of the doors and ignition.
That reminds me..it's about time.
Re: Good Oil for Locks ? #597288
08/10/05 05:38 PM
08/10/05 05:38 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
dri-slide works well in locks.
iirc it is moly in kerosene or stoddard.
and the can has a needle spout suitable for locks.
Re: Good Oil for Locks ? #597289
08/10/05 06:06 PM
08/10/05 06:06 PM
Houston
kenw Offline
kenw  Offline
Houston
quote:
Originally posted by DNaatz:
So lotsa different advice(s) here.
My specific question relates on what's good for an ignition key that occasionally jams but always eventually starts the car.
I suggest WD40 which I have used in outside door locks and should not harm any electrical wiring it might get into - vs comments on graphite in earlier posts not being good for electrical contacts.
Any other thoughts for lubing the ignition switch tumblers?
actually it's probably not the tumblers. It's the steering lock.
You will notice that when this happens, your steering will only budge one way, meaning it is jammed in one direction. Turn the steering wheel in the direction that it WILL turn and try it. 99/100 this is the problem.
Had a friend once who had sprayed so much stuff in the lock that it wass dripping out of the steering column. I reached in, gave the wheel a yank and it fixed it. He still thinks the lock tumblers were jammed and I only "broke them loose". I highly doubt it, but it's not worth arguing.
Page 3 of 3 1 2 3
