Amsoil and light weight oil
by Bullwinkle007
18 minutes 42 seconds ago
What type of Dog Breeds do you own?
by pengem
26 minutes 46 seconds ago
Calling AR guys - AR 10 Rear Sight options
by stockrex
56 minutes 11 seconds ago
Alexa for seniors
by callbay
Today at 07:05 AM
229.51
by RogerBacon
Today at 06:25 AM
One way to get the rust off under your vehicle...
by rollinpete
Today at 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
Yesterday at 10:47 PM
Rat: Trap or Poison
by WhyMe
Yesterday at 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
Yesterday at 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
Yesterday at 09:41 PM
Serpentine Belt noise
by Tdbo
Yesterday at 09:31 PM
Coolant Leak
by Ducked
Yesterday at 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
Yesterday at 08:44 PM
Avalanche front and rear diff change.
by spasm3
Yesterday at 08:40 PM
Abuse proof rental home flooring
by Oldtom
Yesterday at 08:17 PM
Low Noise Oil
by Ducked
Yesterday at 07:55 PM
2017 Dodge charger review
by gabriel9766
Yesterday at 07:51 PM
Dry reusable air filters?
by WillB
Yesterday at 07:42 PM
Batteries @ Menards
by Tdbo
Yesterday at 07:29 PM
Blotter Spot Test
by Emanuel
Yesterday at 07:22 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
80 registered (4WD, BAJA_05, A_Harman, 2004tdigls, 2015_PSD, Andrei, 6 invisible), 1445 Guests and 98 Spiders online.
64253 Members
65 Forums
278525 Topics
Page 3 of 3 < 1 2 3
#597284 - 05/07/05 06:16 AM Re: Good Oil for Locks ?
04.SPT.WRX Offline
Loc: Southeastern, PA
I knew a Medeco authorized locksmith several years ago who swore by this stuff:
http://www.super-lube.com/product_description.htm
I have been using it ever since.
#597285 - 05/07/05 06:26 AM Re: Good Oil for Locks ?
VaderSS Offline
Loc: Cordelia, CA
Mobil 1 spray works great, if you already have some.
#597286 - 05/10/05 05:33 AM Re: Good Oil for Locks ?
John K Offline
Loc: Loveland, Ohio
Probably not the issue but I've been warned to not use key rings with lots of keys because the weight can wear out the lock, going over bumps etc. Some people have lots of stuff hanging off of their key rings..... Something I never thought of until the Honda service manager pointed it out. He used the criteria that if he could hold the ignition key between thumb and forefinger it was ok.
#597287 - 07/11/05 02:46 AM Re: Good Oil for Locks ?
Jim 5 Offline
Loc: Calgary Canada
GM Specifically recommends 5w30 on the locks and ignition of my '98 K1500. It's pretty easy to come by. I usually dip my key halfway in 5w30 and then run it in and out of the doors and ignition.
That reminds me..it's about time.
#597288 - 08/10/05 05:38 PM Re: Good Oil for Locks ?
kc8adu Offline
Loc: dayton oh
dri-slide works well in locks.
iirc it is moly in kerosene or stoddard.
and the can has a needle spout suitable for locks.
#597289 - 08/10/05 06:06 PM Re: Good Oil for Locks ?
kenw Offline
Loc: Houston
quote:
Originally posted by DNaatz:
So lotsa different advice(s) here.
My specific question relates on what's good for an ignition key that occasionally jams but always eventually starts the car.
I suggest WD40 which I have used in outside door locks and should not harm any electrical wiring it might get into - vs comments on graphite in earlier posts not being good for electrical contacts.
Any other thoughts for lubing the ignition switch tumblers?
actually it's probably not the tumblers. It's the steering lock.
You will notice that when this happens, your steering will only budge one way, meaning it is jammed in one direction. Turn the steering wheel in the direction that it WILL turn and try it. 99/100 this is the problem.
Had a friend once who had sprayed so much stuff in the lock that it wass dripping out of the steering column. I reached in, gave the wheel a yank and it fixed it. He still thinks the lock tumblers were jammed and I only "broke them loose". I highly doubt it, but it's not worth arguing.
Page 3 of 3 < 1 2 3
