Mobil Truck & SUV 5w40, 10k miles on sample, 110k on engine.
Iron-40
Chromium-2
Lead-19
Copper-5
Tin-0
Aluminum-4
Nickel-1
Silver-0
Silicon-4
Boron-53
Sodium-19
Potassium-5
Magnesium-96
Calicum-2202
Phosphorus-748
Zinc-952
Molybdenum-77
Fuel-A
Water [email protected] cST
TBN-5.87
soot-.1
Ox-20
Nitration-11
Thoughts? Predictive Maintenance Services says that the additive package changed drastically, although I thought I was still using Delvac1/Mobil T&SUV and the Viscosity has dropped nearly to the bottom of the 30weight range. This is mostly running B99... I thought BD was supposed to make your oil *thicker*, if anything? Can anybody explain what's going on here? Is the Pb or Fe number something to be concerned about?
I'm fairly certain this oil was the "old" T&SUV, not the new stuff, but I could be wrong.
Is it possible that oil contamination with BD would cause the drop in viscosity without testing postive for "fuel", aka petrodiesel?
Iron-40
Chromium-2
Lead-19
Copper-5
Tin-0
Aluminum-4
Nickel-1
Silver-0
Silicon-4
Boron-53
Sodium-19
Potassium-5
Magnesium-96
Calicum-2202
Phosphorus-748
Zinc-952
Molybdenum-77
Fuel-A
TBN-5.87
soot-.1
Ox-20
Nitration-11
