Make: Kubota
Model: 105X
Engine: 105 hp turbocharged 4 cylinder
Oil used: Amsoil ACD 10W-30
Hours on sample: 241 hrs
Hours on Tractor: 311
Sump Capacity: 11 qts.
Oil Filters: BE-90 & EaO15
Oil analyzed by: OAI
First row with 30 hours was used to established a baseline. Second row is the current test with 241 hours on the oil. After the second test came back good, I changed out both oil filters and installed a EaBP100 & and EaO26 on the bypass mount.
Between the first and second test about 12 oz. of make up oil and about 10 oz. of LC20 was added. I also started running B20 soy biodiesel when the tractor had about 150 hrs on the odometer.
In terms of use, I know that during about 75%-80% of the 10W-30's life, the tractor was used in pulling a plow or other similar type work that caused the fuel economy to go into a freefall. In other words, we worked this tractor hard. The wear rates seem reasonable considering this is turbocharged 4 cylinder engine. However, I do not have enough experience with using hours as a unit of measurement to determine if anything would be out of order.
Iron 2 14
Chromium 0 0
Lead 1 0
Copper 2 7
Tin 0 0
Aluminum 0 8
Nickel 0 0
Silver 0 0
Silicon 8 10
Boron 1 1
Sodium 0 0
Magnesium 12 17
Calcium 3279 3514
Barium 0 0
Phosphorus 1142 1118
Zinc 1433 1468
Molybdenum 1 0
Titanium 0 0
Vanadum 0 0
Potassium 0 0
Fuel VIS @ 100 C 10.89 10.49
Water 0 0
Soot/Solids TR 0.1
Coolant NO NO
TBN: 10.68 8.65
OXID: 19.0 17.0
NITR: 3.0 8.0
F-SOOT: 0.01 0.01
Any comments?
Model: 105X
Iron 2 14
Chromium 0 0
Lead 1 0
Copper 2 7
Tin 0 0
Aluminum 0 8
Nickel 0 0
Silver 0 0
Silicon 8 10
Boron 1 1
Sodium 0 0
Magnesium 12 17
Calcium 3279 3514
Barium 0 0
Zinc 1433 1468
Molybdenum 1 0
Titanium 0 0
Vanadum 0 0
Potassium 0 0
Water 0 0
Soot/Solids TR 0.1
Coolant NO NO
TBN: 10.68 8.65
OXID: 19.0 17.0
NITR: 3.0 8.0
F-SOOT: 0.01 0.01
Any comments?
