Did first OA at 13,609 miles, ran the factory fill for 3000 miles and changed to Shell Rotella T 15W-40 to this point. I then ran Schaeffers 7000 series for almost 3000 mile but had to have a head gasket replaced. I found my truck in the bay with antifreeze standing in the cylinders, Story to long to post here. They drained the Schaeffers and put in motorcraft 15W-40 which I ran for a short while and did not bother with an OA. I now run Schaeffers supreme 9000 5W-40. Its first OA will be in the second post. Let me know what you think.
Vehicle ID: 04 F-350 6.0 PDS
Injectors: C-95
Air Filter: Motorcraft
Changed/Cleaned: No
Oil Filter: Motorcraft
Changed: Yes
Bypass Filter: No
Changed: N/A
Oil Brand Shell Rotella T
Grade: 15W-40
Sample Date: 8/31/2004
Total Vehicle Miles: 13,609
Oil Service Miles: 5257
Changed: Yes
Make up Quarts: 0
Aluminum: 3
Chromium: 1
Iron: 32
Copper: 2
Lead: 2
Tin: 2
Molybdenum: 1
Nickle: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 12
Boron: 0
Silicon: 28
PPM/Mile Calculations
Aluminum: 0,0006
Chromium: 0.0002
Iron: 0.0061
Copper: 0.0004
Lead: 0.0004
Tin: 0.0004
Silicon: 0.0053
Sodium: 4
Calcium: 3520
Mangesium: 8
Phosphoris: 1060
Zinc: 1212
Barium: 1
Oil Viscosity Target 69-78: 63.1
Flashpoint F >410F: 415
Fuel % Antifreeze % 0
Water % 0
Insolubles % 0.3
Injectors: C-95
Changed/Cleaned: No
Changed: Yes
Bypass Filter: No
Changed: N/A
Grade: 15W-40
Changed: Yes
Make up Quarts: 0
Aluminum: 3
Chromium: 1
Iron: 32
Copper: 2
Lead: 2
Tin: 2
Molybdenum: 1
Nickle: 0
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 12
Boron: 0
Silicon: 28
Aluminum: 0,0006
Chromium: 0.0002
Iron: 0.0061
Copper: 0.0004
Lead: 0.0004
Tin: 0.0004
Silicon: 0.0053
Sodium: 4
Calcium: 3520
Mangesium: 8
Phosphoris: 1060
Zinc: 1212
Barium: 1
Water % 0
Insolubles % 0.3
