Hi,
this is a really great report - a great match of engine and driving environment to oil choice
In Delvac 1 5w-40, the TBN can be taken down to;
1% @ D4739 or,
2% @ D2896
I presume that the soot is shown as insolubles
If this is so the soot level of 0.6% is extremely low. This oil will easily tolerate 3.5% in your engine due to the way in which it handles soot (I have used it to levels way beyond that)
Whilst the viscosity is slightly out of the Lab's range, an increase of up to about 25% is acceptable in this engine with this oil
The filter should not be a problem up to about 20k miles if it is a OEM (MANN, Mahle, Knecht etc)as they are suitable for use way beyond that. However with all filters the Manufacturer's limit is best to follow up to about +10%
Regards
Doug
