just stumbled across the place - please forgive any newbie transgressions...
'92 F250 IDI w/ 234k miles. old style Amsoil 2qt bypass was there when i bought her in '97. since then i have always used annual oil change intervals, changing both filters at the same time. 15k+/yr lately.
if it matters, in the last few months: first ever Amsoil AF, started using the powderchoke full flow OF, removed CDR & replaced with RDT.
just learned of Blackstone quite recently, & only have 2 samples under my belt - 3rd will be @ 6k+ on current oil, April 01? so, still learning to interpret the results... any help or advice would be appreciated.
obviously, i am concerned about the lead/bearing levels.
----------02/27 / 01/26
---------4223mi / 2750mi / univ avg
Aluminum 1 / 1 / 3
Chromium 1 / 1 / 2
Iron 29 / 25 / 67
Copper 1 / 1 / 6
Lead 15 / 11 / 8
Tin 1 / 0 /1
Molyb 5 / 5 /23
Nickel 0 / 0 / 1
Manganese 0 / 0 / 1
Silver 0 / 0 / 0
Titanium 0 / 0 / 0
Potassium 14 / 0 / 2
Boron 4 / 0 /122
Silicon 2 / 3 / 8
Sodium 8 / 7 / 12
Calcium 3096 / 4149 / 2682
Magnesium 10 / 15 / 218
Phosphorus 991 / 1072 / 1080
Zinc 1080 / 1171 / 1239
Barium 0 / 0 / 0
----------- actual / should be
Sus Visc 74.3 / 68-80
Flashpoint 450 / >410
Fuel Antifreeze 0 / 0.0
Water 0.0 / Insolubles 0.4 /
TBN read 9.0 on the 2750 mile sample, didn't bother for #2
thanks in advance for any input,
Frank
[ March 23, 2005, 03:32 AM: Message edited by: soulpatchfr ]
Aluminum 1 / 1 / 3
Chromium 1 / 1 / 2
Iron 29 / 25 / 67
Copper 1 / 1 / 6
Lead 15 / 11 / 8
Tin 1 / 0 /1
Molyb 5 / 5 /23
Nickel 0 / 0 / 1
Manganese 0 / 0 / 1
Silver 0 / 0 / 0
Titanium 0 / 0 / 0
Boron 4 / 0 /122
Silicon 2 / 3 / 8
Sodium 8 / 7 / 12
Barium 0 / 0 / 0
Frank
