Quick_lude
Thread starter
Originally posted by Tony B:
Get some load on the truck and get some 3/4- full throttle pulling up hills in on the motor and that might help seal the rings for you. The best is to have a load on the engine and let the engine work the load thru its entire RPM range....i.e. no quick shifts and let the engine take its time working up the RPMs when you are low in the RPM range. You don't want to lug the engine, but definately make it grunt some when on the low rpm end.
T
T [/QUOTE}
I'll give it a shot.. Are you saying that the rings can still be seated now, even with 40K km on the engine?
