Ran this oil after draining out Amsoil 5w30 HDD due to abnormal sodium/potassium readings. Contamination occured when I installed my bypass filter and had disconnected the EGR coolant line while oil sending unit was removed and sloshed some coolant into the sending port.
This report confirmed that the coolant issue was not chronic.
Check out that 6.0 vis.
Oil Analyzers Lab, unreported items are 0
Fe 8
Pb 1
Cu 3
Al 2
Si 7
B 1
Na 1
calcium 3307
phosphorus 1189
zinc 1337
moly 90
Fuel Vis 12.48
soot/ .09
solids
Nit. 10.0
Oxid. 13.0
TBN 10.48
Fe 8
Pb 1
Cu 3
Al 2
Si 7
B 1
Na 1
calcium 3307
phosphorus 1189
zinc 1337
moly 90
Fuel Vis 12.48
soot/ .09
solids
Nit. 10.0
Oxid. 13.0
TBN 10.48
