Redline 5w-40
Cat SOS Lab
Miles on oil: 5000
Miles on motor: 105000
Vis @100C 14.8
Al 5
B 2
Cr 1
Cu 6
Fe 16
Pb 2
Mg 192
Mo 764
Ni 1
Si 9
Na 15
Sn 0
Zn 1611
Soot .27%
Water 0
Fuel 0
Anti-freeze 0
TBN 9.5
Car is driven about 80% highway and 20% creep and go on what we call a freeway.
This is the mid point of the third full Redline oil change cycle. This will be the final point of the baseline.
Fuel Power was used during the period as a fuel additive.
The MAF failed about 2000 miles into the interval, and the result was more soot. The timing is also about three degrees retarded as compaired to the last analysis.
OEM oil and air filters were used.
Cat SOS Lab
Miles on oil: 5000
Vis @100C 14.8
Al 5
B 2
Cr 1
Cu 6
Fe 16
Pb 2
Mg 192
Mo 764
Ni 1
Si 9
Na 15
Sn 0
Zn 1611
Soot .27%
Water 0
Fuel 0
Anti-freeze 0
TBN 9.5
