Ok, here are the stats and such for my first oil analysis. The car - 2003 Jetta TDI Automatic. Sample taken during 20k oil change. 1\2qt make-up oil added 7350 miles into this drain. Stock air and fuel filter (both changed after sample was taken as part of 20k service). I installed a Fumoto drain valve during the 5k oil change. 6oz of PowerService added every fill up (silver or white bottle, depending on temp).
Analysis by OAI
Oil: Mobil Delvac1 5w40
Oil Filter: OEM VW (#074 115 562)
Miles on sample: 9718
Miles on engine: 19634
Iron - 50
Chromium - 11
Lead - 2
Copper - 11
Tin - 0
Aluminum - 12
Nickel - 6
Silver - 0
Silicon - 2
Boron - 20
Sodium - 1
Magnesium - 468
Calcium - 2284
Barium - 0
Phosphorus - 1050
Zinc - 1391
Molybdenum - 1
Titanium - 0
Vanadium - 0
Potassium - 0
Fuel %Vol - less than 1
Vis @ 40 C - NA
Vis @ 100 C - 14.20cSt
Water %Vol - 0
Soot\Solids %WT - 0.8
Glycol - NEG
TBN - 4.91
OXID - 22.0
NITR - 18.0
F-SOOT - 0.84
Change - YES
OAI recommendations: "No corrective action required. Oil is suitable for continued use. Resample at next regular interval." blah blah
My previous oil change at 10k was on 9-7-03, and this sample was taken on 4-18-04 - 7 months. I put the Delvac through the wringer, with a lot of Pennsylvania cold morning starts for only 1 mile commute to work. I know... that's murder on the oil and engine... but I've read posts by others at TDIClub about similar torture tests for Delvac and it came out ok. Once a week I was sure to put some miles on the engine, and about once a month I would go as far as Albany NY (600 miles round trip) to stretch it's legs.
So??? Should I be concerned about the levels for iron, chromium, aluminum and nickel?? The boron was down to 20, I'm assuming that's a good indication the oil needed changing? But I guess the silicon is where it should be! Which numbers (besides TBN) might have been skewed by the 1\2qt of make-up oil I added about 7350 into this drain?
Anyway... I'm a novice.. I want to hear from the pros.
Thanks.
- sean
